rage man
went to new brunswick last weekend left my key in the hotel room got them to mail it to me wont be here till monday but im supposed to go sledding agian 2 morrow how to i start my 05 rage with no key
NormT
key
If you know the key number the dealer can get you a new one. n
ApexRtxGuy
the dealer should be able to look it up via vin number. if not the original selling dealer (i dont know if you bought it used or not) is suppose to have it on file.
snopup
ApexRtxGuy said:the dealer should be able to look it up via vin number. if not the original selling dealer (i dont know if you bought it used or not) is suppose to have it on file.
Yes..the dealer should be able to supply the key by vin number...
btw...get two or three!!!!
Budweiser
Have you tried other sled or ATV keys? You never know! I just bought a Attak from a friend and its the same key as my Vecter! Same # on the key too!
My 1998 and 2002 Yamaha Warrior ATV's would both start with either key.
Good luck!
Good luck!
p0wd3rp1l0t
i believe you can detach teh key assemlby from teh sled and put another one in its place if you have the key and it will start.
apltx08
Just get your dealer to LEND you a complete ignition w/key (plug in-plug out) of a stock sled either in for service or a freind that isn't riding with the same type of sled and GO!
For the spare key I keep mine in my JACKET in the inner pocket...you always ride with your JACKET so its the best place to keep it.
_________________
_________________
Metallicat
apltx08 said:Just get your dealer to LEND you a complete ignition w/key (plug in-plug out) of a stock sled either in for service or a freind that isn't riding with the same type of sled and GO!
_________________
That's a great idea! I've often thought that I would be so screwed if I happened to lose my key while in a restaurant or drop it in the snow and couldn't find it again. Not too many other ways to start your sled without a key!
I to keep it my jacket pocket, but I use a large safety pin to pin it to jacket pocket so it will not come out when i take stuff out.
YAM182
- Dec 19, 2003
Hide a spare key under the hood.Find a wiring harness and
wrap with black electrical tape and it looks like the tape is supposed to be there.
Nobody knows where it is but you.
YAM182
- Dec 19, 2003
Local dealer has a box of blanks.
Just need to have them cut to same #.
terret725
if it was a polaris it would be easly theres only 5 differnt keys yamahas on the other hand alot more. maybe hundreds i know my 97 xtc key is 100 or so numbers off of my phazer key. not saying theres all thoes numbers in between but i know theres atleast 4 cause me or my brother has had numbers between thoes 2
