YamaHank
So I just picked up a 2018 viper rtx. I used to have a 2014 LTX-Se. Noticed this sled doesn’t have an exhaust temp sensor...just a bolt in the spot where my last sled had the sensor.
Is this something that was stripped? Can I simply add one and is there a pigtail I can plug it into? Dealer not open till Monday an I am curious if anyone knows -Thanks
PAvector
I believe the sensor was eliminated in 2016
Mtnviper
Vendor
It actually was an oxygen sensor and is no longer used with the current ECU calibrations. You should be good to go without it!
YamaHank
This is helpful thanks - now I need to understand why the two thumb screws on the upper front corners of the shrouds are missing. Did Yamaha do away with those as well or did the dealer forget to put them back in after set up?
Robinmaine
They did eliminate those thump screws.
YamaHank
That’s annoying. The fit/finish here sucks now. Anyone have a part# on these? I’d like to order some if they are still available - Its impossible for me to pinpoint on the microfiche.
allyammies
Don't bother with them they do very little.
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Fit and finish with both of my vipers is just fine without them?
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
I believe if you search a 2014 RTX Shroud the knob and speed nut are parts 67-68. Take a look to confirm.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
My thumb screw fell off in the woods someplace in northern Michigan and has performed great ever since maybe better. Think of it as a weight saving.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
X2My thumb screw fell off in the woods someplace in northern Michigan and has performed great ever since maybe better. Think of it as a weight saving.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Missing thumb screw is worth 3HP
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
5hp if your turbo'dMissing thumb screw is worth 3HP
X3 MI has it somewhere
