DANX123
AIRWOLF
Guest
what do you weigh with all your gear on ?
you can change the clip position on the rear spring or go to the BIG BOY SPRING
Turk
Tech Advisor
Change the clip under the spring in the rear shock to the 3rd position. No more bottoming. I have a bud that weighs 340. He did this to his Attak & can,t bottom it out at all.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Mydealer says you should not have to change to the big boy spring unless you are well over 300lbs. Just change the clip position.
DANX123
APPROX 200-210 LBSAIRWOLF said:what do you weigh with all your gear on ?
DANX123
I APPRECIATE THE ADVISE. IM LOOKING IN THE OWNERS MANUAL AND ALL I SEE FOR THE REAR SHOCK IS THE ROUND ADJUSTABLE COLLAR.Turk said:Change the clip under the spring in the rear shock to the 3rd position. No more bottoming. I have a bud that weighs 340. He did this to his Attak & can,t bottom it out at all.
IS THAT WHAT THE REAR CLIP IS ? IF NOT WHAT SECTION OF THE OWNERS MANUAL COVERS IT.?
AIRWOLF
Guest
TO CHANGE THE CLIP POSITION YOU NEED TO PULL THE SHOCK FROM THE SKID and put the shock in a spring compressor and then move the clip.
you should only have to move the clip to the 2nd postion
very easy job
very easy job
DANX123
thanks
that solves that problem/ thanks how do you remove the shock? any tips?>
the ra adjuster will rotate 2 full turns be sure you are on full hard and not in the middle
sk-rx1
Another factor in the bottoming seesm to be the position of the transfer rod. If you set up for minimum transfer you share the rear weight a bit more. Mine only sags 38mm now, was about 42mm when the dealer set it up new. But since then I moved the transfer to 1/2 toward minimum, to keep the skis from popping in the air due to so much transfer on cormer exit.
sk-rx1 said:Another factor in the bottoming seesm to be the position of the transfer rod. If you set up for minimum transfer you share the rear weight a bit more. Mine only sags 38mm now, was about 42mm when the dealer set it up new. But since then I moved the transfer to 1/2 toward minimum, to keep the skis from popping in the air due to so much transfer on cormer exit.
I just came back from my first real ride on my Attak. If you're trying to get more weight on the skis don't you want to go with more weight transfer rather than less? I'm a novice on the sleds so forgive me if this is a stupid question. :ORC
sobfrogg
If you jump and ride aggresively get the BIG BOY spring.
I am 260 w/ gear.
I have the higher rate spring and have it on the 3rd clip.
I can get the rear skid to bottom very lightly. That is the way you want it. If the skid does not bottom lightly every now and then you are not using the full travel of the suspension.
If you want to lift the skies move the transfer more to max. If you like doing wheelies and tail walks move it to MAX....
Have fun
I am 260 w/ gear.
Have fun
