Turboflash
- Mar 18, 2019
- Southern MN
More likely printing is not straight. Lay belt on flat table and it probably will lay flat.Looks like the 1 is buried in the cog. Also notice how crooked the belt is cut!View attachment 151737View attachment 151738
fourload
Snow sucks up here in upstate NY also. At least 5 more days before some colder weather hits. I am wearing the paint off my sled from waxing it! All of my riding buds including me are on suicide watch!You can see the 1 in one of the lines there, it's 30-19 and the same as the two I received from ShadeTree.
I'm still waiting for my replacement belt, but waiting for snow too that does not seem to be coming so we can ride. So both snow and replacement belt are AWAL, more than likely both are caught up in the holiday rush and shipping backlog.
Turboflash
- Mar 18, 2019
- Southern MN
We all feel for ya! Sucks to be itching to go and Mother Nature won't be kind.
After a decent start, Mpls just had a major rain event the last few days and wiped out our snow cover. Good news is snow is great up in northern 1/3 of state where the same storm dumped 18-20" and it stayed cold so it's dialed in. I'm heading up there tomorrow for a week. Finally can do some testing.
Praying for ya all!!
WinterWolf
- Mar 25, 2017
- Connecticut
Did all these defective ones come from shadetree? I just ordered one from Dennis Kirk...I gotta go look at the date on it???
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
If these start blowing it will be game over for the good reviews of Timken's XS825. I happen to know one guy who's already blown a new XS825 at 134 MPH. Was out of gear but still, it shouldn't be blowing.
When I was drag racing we set them up to go thru OD, run out of gear and pick revs about 50-100 foot before the finish line. I never blew belts ever.
fourload
Mine and Knapps did but they could be scattered through different vendors.Did all these defective ones come from shadetree? I just ordered one from Dennis Kirk...I gotta go look at the date on it???
Preacher
Hey brother I hope all is well I just received 2 Ultimax 825 belts and I was wondering if there is a right way and a wrong way to install these.I remember my Yamaha belts for my Apex had an arrow pointing in the direction of travel.these don't have that arrow. Does it not matter ?Thanks brotherAlways get mine from OEMcycles on ebay and he always uses a proper size box and packing so cant get hurt.
That almost looks like it got "back bent".
Dan
RAMSOMAIR
Put it on so you can read the numbers and letters from the left side of sled. Always put back on in the same orientation.
Turboflash
- Mar 18, 2019
- Southern MN
Technically, the XS belt is not directional. It can be installed in either direction. However, once installed and run, ALWAYS run it that same way.
If anyone has some time on their hands whiel they're waiting for snow, here's a couple links to look at. About 1/2 way through the 1st one, you can see how they mark/stamp the info (date code) referenced earlier in this thread. And, in the second one, the main Timken design engineer talks about how to break in a belt and some other interesting things about failure.
Turboflash
- Mar 18, 2019
- Southern MN
IMO, one thing we should be aware of and the Timken engineer alludes to it ... since the XS belt is a high-temp compound and is aggressive gripping the clutch faces, we MAY be able to reduce side pressure on the belt (because it grips so good) without it slipping. That would lower belt temps and make it live longer. To me, that might mean lower rated springs in either primary or secondary or both?
The engineer alludes to the fact that most failures occur because of high "hub" load (hub load is the total load/pull on the belt in the linear axis) and the subsequent heat generated, and/or high side pressure causing the top of the belt to "dish" which means become concave as we are looking at from the top. That can cause separation at the cord line in the belt.
When I'm testing this week, I'm gonna see if I can put any of this into action. Less side pressure (without slipping) if I can. I got 2000 miles out of my XS belt last year so maybe I'm good the way I am. Still gonna try and see if belt temps come down any (my belt temps are cool anyway), performance stays same (or gets better
KnappAttack
- Feb 19, 2004
- Welch MN
My replacement came today and Tony was e-mailing me to make sure I received it this morning as well. Great service from Timken. Even got about 3" of snow. Not much but its a start.
Date code on the new one is 22-19. So 22nd week of 19. An older batch then the 30-19 that broke on me earlier.
Turboflash
- Mar 18, 2019
- Southern MN
Yes, but again Timken says there is no change in performance within 7 yrs of date of manufacture as long as the belt is not stored in direct sunlight. So, 22-19 is as good as 30-19, maybe even better IF 30-19 had problems. Brand new (say 1 month since manufacture) isn't necessarily better. We'd all hope no matter what date code they are, they're all the same. That's on Timken to do! Maybe the 22-19 batch is better?
I run XS827 (Cat) for the last 3 years and have never seen what you guys have posted in this thread. Always been the best belt I could find on my 280HP tuned Cat. Let's all hope Timken has a handle on this issue and gets it fixed (or already has).
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
When I'm testing this week, I'm gonna see if I can put any of this into action. Less side pressure (without slipping) if I can. I got 2000 miles out of my XS belt last year so maybe I'm good the way I am. Still gonna try and see if belt temps come down any (my belt temps are cool anyway), performance stays same (or gets better.
Awsome! Can’t wait to hear your results!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I always install so I can read it.Hey brother I hope all is well I just received 2 Ultimax 825 belts and I was wondering if there is a right way and a wrong way to install these.I remember my Yamaha belts for my Apex had an arrow pointing in the direction of travel.these don't have that arrow. Does it not matter ?Thanks brother
I replied to you in another XS belt thread.
Dan
Preacher
Thanks Brother,Happy New Year
