NEW Products!!!!! Radiator delete kit...
The rad can be left in or taken out.
On the XTX it is necessary to remove the tunnel protectors
I really like this and really want one but im not sure how it would work with custom exhaust brackets and custom tunnel work (having a 1/4 inch plate running from my susp mounts back to my bumper) it seems a flat u cooler would be alot easyer to work around. I have always thought the cooling system is weird to say the least and would love to have a more conventional one.
Is there a crossover tube at the rear to tie the 2 sides together? If so do you have a pic of the top ?
Getting rid of weight over the front of the sled and moving it over the rear will help.
The biggest thing i like is getting rid of the radiator so you can access items under the hood. Its a cluster.
looks like you would use a hose to connect the two sides
Yes there is a hose that connects the two together.
Cost is about $480 plus shipping for radiator delete and coolers.
What part of canada?
here are some pictures of removed radiator and rear hose.
