shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
We have been testing a few new springs with great results. My clutches are not machined and I am pulling 14mph of overdrive with no coil bind or shimming. Waiting on final prototypes from supplier to test, We had a couple changes. These springs are also clocked to wrap like a normal Yamaha spring. No guessing 3-3 is 60 degrees.
PowderFalcon
Pinnin' it!
interesting stuff shag! keep us posted!
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Super stoked for you guys to finish testing these and Lonn to start shipping them!We have been testing a few new springs with great results. My clutches are not machined and I am pulling 14mph of overdrive with no coil bind or shimming. Waiting on final prototypes from supplier to test, We had a couple changes. These springs are also clocked to wrap like a normal Yamaha spring. No guessing 3-3 is 60 degrees.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Can you explain what is "14 mph of overdrive"We have been testing a few new springs with great results. My clutches are not machined and I am pulling 14mph of overdrive with no coil bind or shimming. Waiting on final prototypes from supplier to test, We had a couple changes. These springs are also clocked to wrap like a normal Yamaha spring. No guessing 3-3 is 60 degrees.
What speed or rpm does the overdrive start ?
shagman
Vendor
- Feb 18, 2014
It's the gains that you get after you run out of gear. I was geared for 115 mph at 9000rpm and ran 129 mph with that setup.Can you explain what is "14 mph of overdrive"
- Apr 14, 2003
- Hessel, Michigan
As Shagman has mentioned.....all good stuff here.
The secondary needed a spring that would have the same twist and side pressure as the stock spring....but Lonn's spring supplier (which is a great guy to talk to and work with) made a couple samples with very good results. The spring actually has a little more twist and side pressure which made the clutch work better that the stock spring.
If you are machined, it will still give you added performance.
Getting a couple more samples to make sure everything works before winter. Will be testing on grass soon
with stock helix???
- Apr 14, 2003
- Hessel, Michigan
with stock helix???
Yes, stock helix and different angles. The group involved with winders goes from bone stock to flashed sleds at different hpr levels.
- Apr 14, 2003
- Hessel, Michigan
Also testing on the Vipers
Great info guys. Keep us posted when it's official. Taking my SW out on the Grass this fall.
--Buster696--
--Buster696--
- Apr 14, 2003
- Hessel, Michigan
Word from Lonn is 50 springs of the final version are on their way to Thunder Products. Shagman and I should have ours within a few days.
Setting my winder up for winter once again. Will be tearing up my backyard test track on grass. Ran the winder on asphalt this season with good results.....along with @Dieselxtx and @shagman
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
No need to shim any longer with the new spring?
34pontiac
CorrectNo need to shim any longer with the new spring?
shagman
Vendor
- Feb 18, 2014
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Can I pre-buy one of the 50?
