local 25
LazyBastard
Fix your front suspension! You've got progressive crappy springs on the front.
local 25
LB, thanks for taking notice. I put the M-10 on this season,so that kinda wiped out my accessory budget for this year. But next year im gonna put the Ohlins on the front. Although,what would you recomend if i wanted to spend a little $$ for the remainder of this season? Thanks, Mark.
LazyBastard
I would say FORGET the ohlins, not necessary. Just put on a pair of 130 or 140 pound per inch springs on the stock shocks. $90.
Also 04 links and bushings, and 13mm swaybar.
http://www.pioneermotorsport.com/pp_index.htm
gerbie
where did you get those mirror's from? they look pretty nice!
Hookman49
gerbie said:where did you get those mirror's from? they look pretty nice!
They are RS Venture mirrors. I almost went with them for my new 04. But the dealer stated they vibrate quite a bit and you cannot get a cover over them. So I went with the stock RX-1 mirrors.
By the way, if you mount the the stock RX-1 mirrors on the opposite sides (left on right, right on left) you can adjust them to see better.
Ken
Local ,I did the same as lazy said , put on the straight rate springe the new link and I went with the 12 mm bar and then next year go with the simmons skis and you will save money over the ohlins and it will handle better .
Ger
Ger
KEITHFD
The simmons skis were the best upgrade I've made. If I was going to do only one thing that would be it.
rx1familyman
I installed the same mirrors on my 03 and have no problem with the cover or vibration. But I installed a water temp guage and you have to mount the guage lower on the dash because of the cross bar between the mirrors. PS like the look of the hand guards on the handlebars.
local 25
the new style mirrors dont vibrate at all,i think it has something to do with the metal bracket that goes between the 2 mirrors. as far as a cover goes i use a covered trailer so i dont even own one.
Hookman49
local 25 said:the new style mirrors dont vibrate at all,i think it has something to do with the metal bracket that goes between the 2 mirrors. as far as a cover goes i use a covered trailer so i dont even own one.
Damn, maybe I should have went for those mirrors after all!
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
Those mirrors also will fit under most covers as the mirrors fold back and fit nicely into the area between the side and middle portions of the windshield.
- 8K
