hpmaniac
- Feb 21, 2025
- Washington
- 2025 mtx sidewinder
2024 9r turbo
2025 summit xpert 165 turbo r
I mean if it's faster on the trail the only 2 things that could cause issues in deep snow is crappy clutching l, not enough grip on belt or poor fuel that don't like the extra load from deep snow. Yes he has clutching for his tune.Did he have any clutching reccomendations ?
I have a hurricane 270 tune in my MTX, pulls hard on the trail, doesn't pull any harder than stock off trail.
Thought I gained some track speed but upon closer inspection the speedo reads 15ish MPH fast.
How much rpm are you running in deep snow on a hard load?
hpmaniac
- Feb 21, 2025
- Washington
2024 9r turbo
Get a Dalton black tan secondary spring, a 35 degree helix or a 35 39 and some Dalton weights along with a xs825 belt and dial in the weights to the rpm dave says. Probably 9100. Also check clutch alignment.Went with the clutching the dealer reccomended, they still don't have an answer for the speedo being way off. On a stock tune with my 17 MTX 162, with some refined clutching, BTX weights maxed out, and 3-3 on the secondary with stock Helix, I would see 55-58 MPH track speeds, that was with the power claw and the Challenger.
I could Punch it from a dead stop and See 40+MPH track speeds by the time the skis were at eye level....
Not quite getting the same effect now.
MK4TDI
- Jan 29, 2020
- Lloydminster Area SK,
- 2014 Summit XMX 800 154
2015 Summit XMX 800 146
2017 Sidewinder MTX162
Yes i would agree with the clutching being off potentially, but i know I'm not the first to have a lack of performance off trail and more specifically mountain riding. Some have went back to stock tuning, which I'm just about at.I mean if it's faster on the trail the only 2 things that could cause issues in deep snow is crappy clutching l, not enough grip on belt or poor fuel that don't like the extra load from deep snow. Yes he has clutching for his tune.
Perhaps I will reach out to him and see if he has a recipe that gets the sled close.
Sled pulls 87-8800 @ 6-7500' elevation
Have those helixs, and the Dalton weights, but I'm pretty sure all Yamaha springs. Didn't notice much difference between the 35 or the variable.
I know the trail guys seem to shoot for 9000-9100 and seems to work well for them, but that's out of the peak torque curve which seems to matter more spinning 162 and 174 3" tracks in 3-4 feet of snow.
hpmaniac
- Feb 21, 2025
- Washington
2024 9r turbo
Dave has mountain specific tuning. That's what I did.Yes i would agree with the clutching being off potentially, but i know I'm not the first to have a lack of performance off trail and more specifically mountain riding. Some have went back to stock tuning, which I'm just about at.
hpmaniac
- Feb 21, 2025
- Washington
2024 9r turbo
If I had to guess,
In the mountains the tune is probably a little rich on fuel and maybe also pulling to much timing based on intake air temperature.
I would talk to Dave about sending a data log.
Tell him it's slow in the mountains.
A larger intercooler is probably almost a must on these if you want constant hp.
Your front clutch is a dyno. Go back to stock tune and see what rpm sled pulls in mountains.
MK4TDI
- Jan 29, 2020
Are you saying the ECU tune itself is specific for mountains or the clutching is ?Dave has mountain specific tuning. That's what I did.
I have read a few guys are having a little better like with the MaxSpool tunes for mountain riding.
Yamaha's factory tune is for it to be running in an ambient temp of around -20 celsius, So they are always running rich, which has me considering adding the 02 sensor and tuning...
My sled also has the CR CAI out of the hood and a 3" resonated straight pipe exhaust also made by CR so it definitely can breath properly.
The intercoolers don't do much on the sleds when mountain riding other than hold snow and add weight to the nose. If I know I have a bigger pull coming up (1-2 Minutes) I will make an effort to get all the snow out from around the intercooler. I definitely does help.
the stock tune and the clutching will pull 8700-8800 alll day long like it did for the first 1500 ish miles. If I want to ride it hard around home (3000 foot elevation) it needs another 4 grams of tip weight to keep the rpms below 9000.
Clutch offset is good, Ive had the bearing out and replaced and green loctite back together.
hpmaniac
- Feb 21, 2025
- Washington
2024 9r turbo
Yes he has tunes max spool that are designed for mounting riding, he explained to me about how the boost is more consistent. Also he said the closed loop tuning is a game changer in the mountains, never rich never lean. Ecm is making live adjustments to fuel just like your newer car or truck.Are you saying the ECU tune itself is specific for mountains or the clutching is ?
Dave makes a intercooler that mounts where the airbox is. He said that with a fan on it is amazing for intake cooling. Overkill for 270 tune but it will keep power consistent on long pulls. Once the intake gets above a certain temp the ecm pulls timing and hp drops. Probably why people report big power increases on trail but not much different in mountains.
MK4TDI
- Jan 29, 2020
Well turns out I had a Turbo Dynamics tune in my sled, somehow ended up with 9 or 10 tooth drivers in the tune, so that put the speedo way out. Got a reflash, speedo is accurate once again. TD said there isn't much to gain with the max spool at elevation, and those tunes are more picky with fuel at Elevation. TD's 270 tune also doesn't have/require a 3 bar map sensor. I have seen up to 17.5psi on the dash down at 1500 feet which would over the 2 bar map sensors ability I would think.Yes he has tunes max spool that are designed for mounting riding, he explained to me about how the boost is more consistent. Also he said the closed loop tuning is a game changer in the mountains, never rich never lean. Ecm is making live adjustments to fuel just like your newer car or truck.
Looks like Hurricane suggests having the 3 Bar map sensor on all his tunes now.... not sure if I should just bite the bullet and get the hurricane high elevation tune and sensor for another $900 or just try to get this TD tune clutched better
hpmaniac
- Feb 21, 2025
- Washington
2024 9r turbo
How much weight in primary and what spring? I have seen 18.4 lbs boost at 5k feet with my hurricane 270 pm tune.
MK4TDI
- Jan 29, 2020
Dealer that tuned it suggested Thunder Products Orange in primary, with glide washers and their heavy hitters at 72 grams, also their Orange secondary spring at 6-1 with the straight 35 helix. That's at 1700 feet, cluster was saying 22-2300 feet elevation.How much weight in primary and what spring? I have seen 18.4 lbs boost at 5k feet with my hurricane 270 pm tune.
sled pulled not bad up top but was lazy on the bottom end,
hpmaniac
- Feb 21, 2025
- Washington
2024 9r turbo
I am running the dalton black orange spring and 35 helix, orange silver orange primary and dalton weights loaded to about 78 grams. Pulls 9k rpm at 6kfeet. Backshift is good, I think i can get away with a straight 42 or so helix and gain more track speed quicker.
MK4TDI
- Jan 29, 2020
Last time in the hills 6000 -7500 feet, I had the Dalton QAY70 @ 70.6ish grams, Green white Green yam spring, and that pulled decent at 88-8900, however that was with the white Secondary spring @3-3 in the 35 helix and the 35-39 helix, had less jam than my stock tune set-up.I am running the dalton black orange spring and 35 helix, orange silver orange primary and dalton weights loaded to about 78 grams. Pulls 9k rpm at 6kfeet. Backshift is good, I think i can get away with a straight 42 or so helix and gain more track speed quicker.
I have a straight 37 helix coming from Dalton, and I think I might get a Purple EPI secondary spring to bring with me, along with the Dalton black orange and black tan on our trip to the hills next week. That sled should pull 68-70MPH track speed with the add hp... just have to find the recipe for it.
hpmaniac
- Feb 21, 2025
- Washington
2024 9r turbo
The stock mtx helix is a 35-39? i get them mixed up, 39 -35 or 35-39?Last time in the hills 6000 -7500 feet, I had the Dalton QAY70 @ 70.6ish grams, Green white Green yam spring, and that pulled decent at 88-8900, however that was with the white Secondary spring @3-3 in the 35 helix and the 35-39 helix, had less jam than my stock tune set-up.
MK4TDI
- Jan 29, 2020
stock one is the straight 35, the dealer that tuned the sled gave me a new helix to try when Yam released it on the SRX I think, anyways has 8Ck70 stamped on the side of it, from what I can find on the net its a 35/39The stock mtx helix is a 35-39? i get them mixed up, 39 -35 or 35-39?
MK4TDI
- Jan 29, 2020
Well was out doing some testing yesterday, wrapped the TP orange to 6-2, and the sled became a whole other animal... still a little bit lazy out of the hole however.
But broke the bellow on the exhaust, put a whole in the gas tank and had a small fire... so parts hunting now
