Scooter02
- Nov 26, 2007
- Oak Creek, WI
- Yamaha Viper LTX LE
So I loaded the three sleds that I have now in the trailer, from the rear with them all facing forward. I’m going to have to load them from the front facing out the back, or in the 69 position ( if loading from the rear) to get the 4 in the trailer, as there wasn’t a lot of room leftover. I will have to play with the configuration in fall once I have all four sleds, as the trailer is in summer storage now.
Thanks for your comments and recommendations.
Scott
Scott
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I have a 7x22+5’ V always load from the front. Much easier to unload heading out the back. We load 153,146, and 2-144’s that way but it is tight
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
I just bought a 2021 Legend 14 ft with a 5 ft V. Inline. 7 ft wide inside. 19 ft total with the V. Will I be able to fit 2 Yamaha XTS. Vectors. 146 inside? Or do I need to buy 1 Sidewinder or Thundercat 137. With King Air. To make this work. The trailer is so nice. My Wife is trying to figure out how we can camp in it! Lol!
You will get them in there. One might need to go in backwards but you might get them both in frontwards with them staggered With one tight in the nose.
i used to get 3 136” sleds into a 20’+5’ x 6’ wide trailer. I get 1 151, 1 144, 1 146 and 2 136 sleds into a 20’+5’ x 8’ trailer now.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Unfortunately you will need to buy the winder and T cat give 1 to me -THEN it will all fit and look right in the trailer.I just bought a 2021 Legend 14 ft with a 5 ft V. Inline. 7 ft wide inside. 19 ft total with the V. Will I be able to fit 2 Yamaha XTS. Vectors. 146 inside? Or do I need to buy 1 Sidewinder or Thundercat 137. With King Air. To make this work. The trailer is so nice. My Wife is trying to figure out how we can camp in it! Lol!
I have a 7 foot trailer and find with staggering right and left its amazing how sleds fit. I have never had to put one in backwards but hear of it often- I doubt you will need to do this.
sab2022
- Feb 21, 2020
- Maine
- 2023 Sidewinder S-TX GT
Suggested caliber snow products
nhtrailers.com
Snowmobile Track Mats & Ski Glides - Proline Products LLC
Though not an absolute necessity, many of our customers choose to add some Caliber snowmobile products to their trailer to help protect the flooring. We know that any aluminum trailer you buy is an investment and for this reason, we carry the only the very best in flooring protection from...
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
Thanks for your input. Guess I will have to wait on the Winder. At least I finally got the trailer!
RobX-1
- Coldwater, OH
Unfortunately, those ski guides get complicated with the criss-crossing when installing them in the in-line trailers; not so much with the traditional 8'ft wide trailers though. I used to use Luan plywood to place over my flooring as a means to protect it and surprisingly enough; it held up quite well for 9yrs. The original flooring looks like new with nothing torn up by wear bars and studs. After seeing what my friends have used for their flooring in their snowmobile trailers, I recently put this down:Suggested caliber snow products
Though not an absolute necessity, many of our customers choose to add some Caliber snowmobile products to their trailer to help protect the flooring. We know that any aluminum trailer you buy is an investment and for this reason, we carry the only the very best in flooring protection from...nhtrailers.com
https://www.menards.com/main/floori...22-c-6614.htm?tid=-6032303019401556977&ipos=1
I have a 7.5ft wide x 16ft + 5ft V-nose trailer and the rolls at Menards come in 7.5ft x 17ft. I was able to use scrap pieces that my friends had leftover for the V-nose otherwise I would have just used another sheet of Luan for it. The nice thing about this flooring is that even though its rubber, the sleds go across it real easy and you can even slide the sleds around better too. Sweeping out the snow is also a breeze although my buddies have resorted to using a leaf blower as the snow doesn't pack to it like plywood. The coin pattern also makes it have better traction when walking on it but with it being slick enough for the sleds to slide around, you do have to be cautious; much like the ski guides on ramp doors.
RobX-1
- Coldwater, OH
Before:
After (Well not the final look but a work-in-progress as I can't find my finished photo):
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
That's actually a type of vinyl, not really rubber. That's why the sleds slide across it decent.
sab2022
- Feb 21, 2020
- Maine
I don't see a sled tie down strip?
Anyway, I have the same sheet designed product in my ATV trailer only diamond plate design. The ATV has caused the sheet product to breakaway from the glue and clump-up in one or two places. I press it back down with my foot. I guess the fix is to slice the clump and re-glue. It does improve the look of the inside of the trailer.
RobX-1
- Coldwater, OH
That pick was more of work-in-progress pic as I hadn't trim the flooring yet nor had I cut out the holes for the tie downs. Here's what it looks like now. We did not glue the flooring down but instead used these truss screws. Although it does bubble a little in summer like you can see in picture but wants it gets cold out, it lays down and never had an issue with the flooring bunching up.I don't see a sled tie down strip?
sab2022
- Feb 21, 2020
- Maine
Thanks I try those screws but the rubber/vinyl may already stretched in my case. A finished washer would also work but a little more money. Another problem I had was finding short tie down straps. I understand you can buy straps and cut them, but if you can find pickup truck ramp tie down straps they they come in 6 feet. and the ratchet is designed for 6' not 8', 10' or 12'
dmaxx
- Apr 5, 2006
- sw Michigan
- 2015 Viper RTX, 2012 Apex XTX, 2010 Vector LTX, 2000 AC Z-370..fast
- White Pigeon, MI
Do you have studded tracks? I would think studs would rip it up.That pick was more of work-in-progress pic as I hadn't trim the flooring yet nor had I cut out the holes for the tie downs. Here's what it looks like now. We did not glue the flooring down but instead used these truss screws. Although it does bubble a little in summer like you can see in picture but wants it gets cold out, it lays down and never had an issue with the flooring bunching up.
View attachment 162313View attachment 162314
RobX-1
- Coldwater, OH
Yes, I have studded tracks but no, it does not rip/tear up the floor; althought I don't spin the track alot on it too. With it being a vinyl flooring, the ski carbides do not grab/bite as much and the few times the track did spin was when I was not sitting on it and giving it some throttle to inch it forward when loading up the trailer.
