obr
- Aug 16, 2005
- Alta, Norway
- www.techservices.no
Anybody running any nitrous kits on a Phazer yet?
In that case, where did you mount the bottle?
What kit are you running?
Was thinking about mounting a Boss kit on my Phazer, but I'm not convinced yet....
Thanks.
Thanks.
yamahajunkie
pm monker, i think i read he has it on his phazer.
monker
obr
- Aug 16, 2005
- Alta, Norway
Ok, thanks, Why did you go with the Holtzman?
I can get a used ICE for a fairly cheap price, but I can also get a Holzman out of my friends REV for a good price. I'm just not sure witch way to go.
I've haven't played much with nitrous, but I like that you can bring it back to stock when you sell the sled, a turbo is to much work putting back to stock.
And, on these kits, there are nothing like a boondockers, or tfi box. Shouldn't you have that, as the sled is EFI?
monker
obr said:Ok, thanks, Why did you go with the Holtzman?
I went with holtzman because of the simplicity of the kit. The toughest part is mounting the bottle. The one in the pic is a 1.7lb with a different valve for clearance. I think it has the cleanest install of the others I've seen. There isn't any kind of elec. box added, this is the same setup as what's used on the apex sleds.
obr
- Aug 16, 2005
- Alta, Norway
Ok, thanks. How does this kit add fuel when on the bottle?
I think simplicity is important, but I know they've had trouble making those kits work on some Rev's. Hope you get snow soon...
monker
obr said:Ok, thanks. How does this kit add fuel when on the bottle?
I think simplicity is important, but I know they've had trouble making those kits work on some Rev's. Hope you get snow soon...![]()
Fuel is added into the air-horns in the airbox. Same as the apexs/RXs.
obr
- Aug 16, 2005
- Alta, Norway
ok, thanks, just ordered a Holtzman kit. AND, we have the snow to test it. Will start putting it together next weekend...
obr
- Aug 16, 2005
- Alta, Norway
do you have any better pics of how you mounted the bottle, also of the different valve?
Thanks, MR Bull
Thanks, MR Bull
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Yup, that is just awesome!! Same simplicity as the Apex kits!! That's why I went with the HOLTZMAN kit also.
obr
- Aug 16, 2005
- Alta, Norway
well, only thing I'm concerned about is mounting it, and making it stay there...
wonder how many HP shots you can run on the phazer...
December Snow Tech Mag had an article on adding nitrous to phazer.... just thought i would pass it on.....
obr
- Aug 16, 2005
- Alta, Norway
Thanks, will go out and see if I can find it this afternoon.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Any updates on how the sled worked with the N2O? Thinking of a FX sometime but wondering if the nitrous would get the sled to 100mph on a lake. Thanks!
