DooAssassin
There are no color markings on the old rod bearings and it should have markings. I have a choice between a few different types with yamaha. Its a 07 apex turbo with carrillio rods. What should I do now..
HYFLYR
Plastigauge
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
X2, take a guess and plastigauge and start from there. take your time, its worth it.
TWIN TURBO
That's not uncommon. Most of the time, If the ink number on the rod is a 5 and the crank's marked 1's or 2's the color will be Blue. You can measure the thickness of your old bearing and I can tell you what it is. Plasticgage is your only other choice, crude at best but that's all you can do without the proper equipment for measuring clearences.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
he have carrilo rods, I never seen numbers on these rods.
TWIN TURBO
I was refering to stock rods with the ink number. Carrillo will generally work out the same as a stock rods however.
DooAssassin
