Sled was running fine a week ago after changing oil, then when I plug the key switch in, no power to instrument. Checked to see if power in coming to key switch, the two blades next to the connection lock, if jumped together the instruments come on. Then checked the other side of the connector going to key switch and if I turn key on the same two blades have no continuity, but if I check one blade on lock side and one blade on opposit side with key on, there is continuity. All fuses have been tested good, so went to relays on clutch side and test ign. relay and the book says you must have continuity between red and blue or relay is bad, it looks like the relay went bad. Not sure till I see the dealer, but has anybody had simular problems with the relay? Any help would be appreciated.
never mind...had a brain fart
doooh, turn on kill switch, dummie. This will be one hard to live down.
WANN4STROKE
- Feb 26, 2007
- Anchorage, Ak.
- 2009 Viking
2006 ApxMtn-sold
2001 MtnMax-sold
1998 VMAX 500-totalled
been there, done that!!
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Mike,
I thought about asking you if the kill switch was pushed down but I did not want to insult you. Thank god that you figured it out before taking it to the dealer.
Don't worry, we will never speak of this again!
NY AttakGT
Hey Mike.....HERE"S YOUR SIGN!!! ..hahaha. Happens to the best of us.
--Steve (O.C.)
--Steve (O.C.)
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Re: never mind...had a brain fart
I could delete the whole thread for you for a small fee.
bigdog_mike said:doooh, turn on kill switch, dummie. This will be one hard to live down.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
How about we just settle for letting us know where you live by updating your profile, and we will all go away happy!!
That and we'll know where to stop for a frosty one and give ya hard time for something we've probably all done!
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
I think we should turn this into a Sticky!Crewchief47 said:bigdog_mike said:doooh, turn on kill switch, dummie. This will be one hard to live down.
I could delete the whole thread for you for a small fee.![]()
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Add it to the tech page. Been there done that
