I'm getting 12V at the ignition switch. I tried to clean the terminals but still no start. Where does the pod get the power from? the pod does not light up at all. I hear a single click when I turn the key and a brief flash on the pod. Everything appears to be grounded. I've started the sled several times in the last week. All of a sudden this stopped. I'd like to think it was a simple fuse or dirty plug but I've gone through all that. I guess teh plug/terminals can still be dirty but I would think since it was working just yesterday that I would get a little more than a click and a flash on the pod. What is the path of the power after it leaves the battery? Normally I hear the fuel pump when I trurn the key to on, I dont' even hear that now.
Grizz, I did the probe for 12V on the plug at the relay. The wire you show in the picture(red wire with white stripe) does not show 12V. I do get 12V on the wire next to the one you say probe for ground. this is a red wire with a green stripe. Can you explain what probing for gound means? what should I be looking for?
