no power
darv
International Falls,minnesota
08 Apex 40th LTX
put battery in was on battery tender all the time put in no power check to see if there was power at jumpers at side of sled lighted up test light but still no power could battery still be bad checked fuses on right side by chain case all good where else should i check ( i hate electric problems)
hate electrical problem to cant figure out me im with yamaman check red button if it up down maybe relay check switch with matching one under hood but sure not should get volt check meter accurate reading if under volt 12 new battery needed might be
I'm no English major, but does anyone else have a hard time reading posts without any punctuation?
:tg:
lol thats the entertaining part of the forum....
:tg:
if you have another sled or a electric start lawnmower or anything else like that try swapping the battery's around.
Darv!
Did you get it going?
Either way, let us know. ;)!
I had a battery that had 0 volts before it must have had a wire broken off of the terminal inside. Multimeter is your best friend, test light is not a good tool. Have seen people fry circut bords with test lights.
check starter relay or fuel relay if you dont hear the pump charge...
If you have carbs, you will not hear the pump charge, for you don't have an elec. fuel pump as with fuel injection.
