picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
Do our have a part number for the better shock? Also how much does it cost for the shock? How much to revalve it?
rebmo
- Mar 8, 2014
- Rural SE Wisconsin
- 2015 Yamaha RTX-DX blk
2015 Arctic Cat XF 9000 Green (Turbo)
Cannondale actually sold me a 2016 shock that was re- valved. It has a larger diameter body. But you can remove yours and send to him. I think it's abou 70 for a revalve? The larger shock was from his viper but same original Yamaha valving. I paid over 100 but that included the shock. Pretty easy replacement with skid in. Huge difference compared to the dual rate spring. He did say the dual rate spring is a good idea too.
Just to clarify the shock I sold Rebmo was revalved not stock. The SE's had them and 16 and newer DX models. I charge $80 for a revalve.Cannondale actually sold me a 2016 shock that was re- valved. It has a larger diameter body. But you can remove yours and send to him. I think it's abou 70 for a revalve? The larger shock was from his viper but same original Yamaha valving. I paid over 100 but that included the shock. Pretty easy replacement with skid in. Huge difference compared to the dual rate spring. He did say the dual rate spring is a good idea too.
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
Am I better to buy one of these and have it revalved? Or revalve the old shock?Just to clarify the shock I sold Rebmo was revalved not stock. The SE's had them and 16 and newer DX models. I charge $80 for a revalve.
Buy the bigger shock and revalve. Look for used. I don't have a proven valving package for the 1.5 shock on the 14 and 15 DX.Am I better to buy one of these and have it revalved? Or revalve the old shock?
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
I have 2 sleds that need this badly
Looks to be about $100 for the shock new and revalve is $80. So still way less than buying a aftermarket shock and honestly works almost as well as a $800 fully adjustable shock.I have 2 sleds that need this badly
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
That's not bad at all. I would like to get this done. Do you get the shocks or do I? Also do you accept pay pal?
You would need to get shocks. Is quite the price variances. Looking at Yamaha they are $189 from Port. If you look up a 14 ZR7000 from Country Cat shock list for under $100. It's the same shock! I do accept PayPal but prefer check due to fees. Let me know if you need help finding the shocks too.That's not bad at all. I would like to get this done. Do you get the shocks or do I? Also do you accept pay pal?
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
Ok, I'll get the shocks and get back with you. ZR 7000- 2014? Ok
Yes. Here is Country Cat. Crazy cheap!Ok, I'll get the shocks and get back with you. ZR 7000- 2014? Ok
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
I can get either the cat shock 2704-685 or the '16 viper Rtx-DX Shock for around the same price. Are they the same thing, or is one better?
