No Reverse?
Kkurz
Peterborough On.
Canada
2014 XF7000 Sno-Pro Limited
(Yamaha powered)
So I was in the last 50km of a trip and my reverse stopped working. I've seen the videos about re-clocking the actuator, but mine doesn't sound like it's even trying to shift. Any suggestions? Is there a fuse?
Ok, it is trying to shift. When I hit it this time, it ground the gears with the throttle. I'l have to start tearing into it this aft and see if the gear on the actuator us pooched.
Is there any way I can get the actuator to cycle while the engine isn' running?
Take off the actuator and see if you can shift it with channel locks. It could be the actuator isn’t fully moving.
