Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
So I was in the last 50km of a trip and my reverse stopped working. I've seen the videos about re-clocking the actuator, but mine doesn't sound like it's even trying to shift. Any suggestions? Is there a fuse?
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Ok, it is trying to shift. When I hit it this time, it ground the gears with the throttle. I'l have to start tearing into it this aft and see if the gear on the actuator us pooched.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Is there any way I can get the actuator to cycle while the engine isn' running?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Take off the actuator and see if you can shift it with channel locks. It could be the actuator isn’t fully moving.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
I'l try thanks.
- 10K
