Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I've been having trouble with my reverse for the last couple of rides. The short story, I ended up buying a new one for $320 Canadian and threw it on tonight. Not working! I've been through the actuator threads and they seem to be focused on the gear being ground. Not my issue. You can feel the thing trying to shift if you hold your hand on it, and I think I followed the proper mounting instructions, but it's not shifting into gear. Any suggestions?
You started off with gear in forward? You turned the extension counter clockwise and the notch was down and about in middle for the pawl?I've been having trouble with my reverse for the last couple of rides. The short story, I ended up buying a new one for $320 Canadian and threw it on tonight. Not working! I've been through the actuator threads and they seem to be focused on the gear being ground. Not my issue. You can feel the thing trying to shift if you hold your hand on it, and I think I followed the proper mounting instructions, but it's not shifting into gear. Any suggestions?
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Yup. This is a pain!
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I had to replace mine earlier this winter for $209 plus tax. Went on easy like Cannondale said.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
I've had it on and off in the past, and had no issues.
I think you are going to have to go in chaincase.I've had it on and off in the past, and had no issues.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Ok. Tomorrow I'll pull the actuator off and start over. If i have to crack the chaincase, I will. But I really don' want to! You can't do it without losing the oil and chaincase fluid, can you?
Sure just get whole thing to side with hoses attached. Chaincase oil will be lost but not engine oil.Ok. Tomorrow I'll pull the actuator off and start over. If i have to crack the chaincase, I will. But I really don' want to! You can't do it without losing the oil and chaincase fluid, can you?
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 17600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 3700 km
Pay special attention to the jackshaft, Friend of mine had his chain case all redone under warranty last year and then had problems with no reverse last month, checked the actuator and that was all good. New jackshaft developed a burr that prevented gear from sliding on it. He sanded it lightly to finish off the season before going back to dealer.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Fixed. I just pulled the actuator off and reassembled closely following directions and it works. I don't know what I did wrong, and feel kinda stupid... thanks for the help guys. I hope it has solved my problem! Now on to the clutching and bearing inspection.
- 6K
