big bear-apex turbo
My apex sat over a summer started it a couple times ran fine and then i went to load it up one day and it wouldnt run worth a #*$&@. Got it into my shop and it only has spark on 2 and 3 but no spark on 1 and 4. I bouh brand new iridium plugs for it same as my last set and still nothing i tried closing in the gap and still nothing. The codes come up for no spark on 1 and 4 cylinder as well. Is there a relay or fuse or something or has anyone come across this before?
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
What code numbers are you getting?
Super Sled
- Feb 25, 2009
- Summit X
Maybe not run it long enough those times you fired sled up and foul your plugs? Or else any possibility of mice chewing on wires?
big bear-apex turbo
33, 36, 81. I understand 81 is just grip warmer it hasnt been working for a long time but 33 and 36 are cylinder 1 and 4 short curcit or something? I removed the coil harnes and checked it (continuity) and it seems fine also i cleaned every electrical plug on the machine. It has brand new spark plugs which didnt make a differance (ive had tbe fouled plug problem before)
big bear-apex turbo
And its not the coils because i swapped coils and still doesnt spark on 1 and 4 but 2 and 3 have good spark
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Probably bad battery.
Seems to me like its not getting the timing pulse from the engine to send to the coil for half of the engine.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Aren't the grounding plugs on these a problem as well???
http://www.ty4stroke.com/viewtopic.php?t=83994&start=0
