NOT STARTING
Dumb dumb
I have 08 nytro i rode it in single degree weather this weekend went inside came out maybe 2 hours later an thing wouldnt start engine light was on it would crank over just fine but wouldnt fire towed it to a buddys house left it in his non heated garage overnite an it fired rite away in the morn is it possible iced up or cld it be something else dnt want to get stranded this weekend going on a big trip :o|
It was just showing the engine light was flashing no code was up
You should be able to hear if the fuelpump runs or not when you turn the ignition on.
Generaly:A relay can fail in either the "switch"-part or in the "actuator"-part, if the "switch" part fail, you hear the relay click inn (actuator part works) but nothing more happens.
If the "actuator"-part fail you hear nothing.
As an emergency solution, do as Stan Ridgeway said, "Pick it up and put it in your pocket" :drink:
As a more perm solution, get a new and Grease 'em up, I just bought "Spray Vazeline" for "sealing" the connections
