nytro blowing belts need specs
canoehead said:
rage man said:
found that all 3 plastic bushings the helix runs on aare groves half way through will replace this week think thats enough to cause that issue also THE PRIMARY CLUTCH I CAN MOVE IN AND OUT JUST A LITTLE BIT BUT THERES DEFENTALLY MOVEMENT IS THIS NORMAL ON THE NYTROS I KNOW ON PERVIOUS SLEDS OF MINE AND DADS APEX TYHATS NOT THE CASE
Yes it's normal to a degree. There is some excess play on the stub shaft.
ok thats good was kind worried about that
ill check the weight this afternoon. do you think thoes plastic ramps the helix slides on would be enough to cause this issue if the weights check out ? thx
