max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
sooo in the adapt sec and boss is ron switching to a tortional spring?? from a compression that is stock in both. i dont know if adapt is factory compression or tortional.
justinator
Both adapt and boss come from the factory as compression and Ron’s set up for both clutches is torsional. He includes a carbide drill bit and a template so you can drill a few holes in your roller hub and you also drill one hole in the clutch next to where the Tang goes for the factory compression spring.
