saythey
Just put in my order and I hope it will work with one of your earlier sets. I don't have the plug and play setup.
![](/styles/vip.gif)
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
saythey said:Just put in my order and I hope it will work with one of your earlier sets. I don't have the plug and play setup.
Yes it will work with any of the versions including the Basic hard-wired kits.
![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
You may need to call me to verify a couple connections, yet will work great.
![All Coholic :drink: :drink:](/styles/default/xenforo/smilies/all_coholic.gif)
Rock
![Smiley Faces7 :-o :-o](/styles/default/xenforo/smilies/smiley-faces7.gif)
usaf167aw
ordered mine!
DANX123
i have a 2009 xtx with the pug and play . work pretty good.
i find the left warmer works much much better than the right side?
i also have a set of 2006 apex bars at home? any differance? ideas?
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
DANX123 said:i have a 2009 xtx with the pug and play . work pretty good.
i also have a set of 2006 apex bars at home? any difference? ideas?
If they are the UPDATED Apex bars (Heated hooks), you will like them better than the '09 Nytro bars.
(The Apex Bars are warmer)
The difference in grip heat is pretty common, due to variances in the heating elements.
DANX123 said:i find the left warmer works much much better than the right side?
Ive noticed this on mine as well...weird..
CJW
I think I have the same problem with my 09 xtx. What do i need to do to get a booster also? Thanks
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
CJW said:I think I have the same problem with my 09 xtx. What do i need to do to get a booster also? Thanks
Heyya CJW,
Goto www.yamaheater.com
Then to the Order screen, it is a selection in the Model Pulldown List
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
sj said:DANX123 said:i find the left warmer works much much better than the right side?
Mine are the same also, not too much off, but noticeable.
You can swap the output connectors to the grips from the YamaHeater, will either make it better or worse.
(One lead is longer than the other & has slightly less voltage, so helps even them out a bit.)
DANX123
Rockmeister said:DANX123 said:i have a 2009 xtx with the pug and play . work pretty good.
my 2006 apex bars are the upgraded bars they issued in 2006?
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
DANX123 said:Rockmeister said:DANX123 said:i have a 2009 xtx with the pug and play . work pretty good.
Possibly.
If they have a hole on the outside of the hook bend for the hook mounting screw, they are the early '06 bars. (Non-heated hooks)
No hole, updated bars, fully heated hooks.
Hope this helps!
![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
switch
Thanks for the call yesterday Rock! The call was greatly appreciated. Keep up the great work.
CJW
I just ordered a booster for the plug n play unit i have my 09 xtx. I checked of the box that says it has the heated hooks. I hope that was correct. I wasnt sure. Thanks Rock
srxpert
boost without heater
Can you use this boost without a yamahaheater on it? I have a yamahaheater on my nytro and could use more juice but my apex only needs a little more than stock.Stock they are as hot as my nytros with the yamahaheater on it.Thanks Shane
racingronnie
Just ordered, sure would be nice to get it before New York trip leaving on Jan 29th. Thank you!!
Tug hill or bust.
Tug hill or bust.
- 6K
