m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Hello,
Can anyone help me with the spec for cylinder head torque? Stock engine and head gasket. I just want to re-torque. Cold setting.
pro-man
- Aug 30, 2017
- Lwr Michigan
- vmax-sold
The head bolts are torque to yield , you will need to replace them to re torque.
m.schuey7
- Feb 4, 2014
Do you know the torque spec ?
pro-man
- Aug 30, 2017
- Lwr Michigan
- vmax-sold
Initial torque is 25 ft lbs, loosen and re torque again too 25 ft lbs , then turn each bolt an additional 175-185 degrees. This is done with new headbolts as the old ones cant be reused or retorqued.
m.schuey7
- Feb 4, 2014
OK,
Thank You
Thank You
