ride -4-fun
has anyone set up there nytro for the asphalt ?? thinking of putting mine on the tar . not sure if i should use the stock skid or aftermarket ,if i should change the drivers,and should i go 15" or 10.5 track.... read some where about somebody putting 10 tooth drivers in. any help thanks
Topgun
Yup, I'm in the same boat as you. I know the 10.5 suposedly hooks better, weighs waay less and pulls more mph.. Being as you putting a slick track on you have alot more room to put the bigger drivers, don't know if it is worth it if your still running the stock idlers in the back though. I'm wondering about the cooling though, the Nytro seems to run hot when the thing isn't in alot of snow.I notice some of the apex guys are adding extra rads to cool them down on the tar.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I have an extra Proline skid, Proline Skis and new track (10.5" wide setup) if anyone is interested. Running 10 tooth drivers will help with the approach angle and be more efficient regardless of rear idler size. You will likely need to build a cool down cart to help cool the sled down between rounds as the Nytro doesn't have enough cooling capacity to cool itself nor enough room to add a larger radiator.
I cut the stock coolant line and routed the bottom section back and then used some elbows to come up. Then on the other half I bought a hose that fit and routed it straight back as well. This will allow for cooling down without removing the side panel.
Allen - how much for the set?
ride -4-fun
asked the same question ????
- Apr 17, 2003
- Menno, SD
- Menno, SD
$1900 + shipping for the skid, track, skis. Skid is powder coated black as seen, clicker front and rear shock, brand new track (still has the tag on it yet), and a set of Proline skis with wheels and bearings in good condition.
hlmrx1
Allen, how much for the track by itself?Srxspec said:$1900 + shipping for the skid, track, skis. Skid is powder coated black as seen, clicker front and rear shock, brand new track (still has the tag on it yet), and a set of Proline skis with wheels and bearings in good condition.
- Apr 17, 2003
- Menno, SD
- Menno, SD
$500 + shipping for the track. I currently have someone interested in the whole setup so I will not split the items up currently.
RX-Boy
- Oct 11, 2004
- Alberta Can.
- esmotorcycles.com
PROLINE PARTS
Do you still have proline ashphalt set up for sale ?
RX-Boy
- Oct 11, 2004
- Alberta Can.
- esmotorcycles.com
NYTRO ASPHALT DRAG RACING
Allen-we ran Pinks All-Out a couple of weeks ago and the best time with a stk Nytro was 10.666 @ 118.71 mph @ 2500 ft-It was an awesome weekend-Now I have some customers that would like to do the same-What is the width of the skid you have?
ride -4-fun
i purchased all the pro-line stuff from allen.rx-boy the nytro was completly stock running those numbers ? nothing at all was done.thats pretty good for stock . was it a 15" track or 10.5 track ?. hope to have mine done in a couple of weeks .
RX-Boy
- Oct 11, 2004
- Alberta Can.
- esmotorcycles.com
NYTRO
Stock other than a different muffler-also with 10.5 track & Wahl skid-121"
ride -4-fun
i hope mine will runs those numbers,i'm running a 10.5 track also. just got done switching track ,wasnt bad until you get to putting the chain case cover back on. takes a few times to get the reverse arm to go in right..
