stricklandj
- Feb 21, 2010
- Nova Scotia, Canada
- 2013 Yamaha Nytro XYX 1.75
NFLD-Nytro
scmurs said:Off Trail Mike said:Zipperno
Is that a fuel tank I see behind the seat? AKA the 1973 Arctic cat Panther that had the tank in the exact same spot!
Very sweet sled.....and if that was a gas tank, where did you find it?
OTM
Mike,
That's an Impulse Turbo set up. They put the fuel tank under the seat to make room for the hair dryer where the fuel tank used to be.
Wild.
charlie
charlie
xrrider
charlie
the sled sent me for a ride and yamaha wouldnt fess up to a problem me and by brother up dated to apexs
xrrider
At least you stayed with a Yamaha.
charlie
Ya I had a ski doo 800 got tired I wondering were and when I would need a piston yamaha has the best motor
jonnyz36
northernxtx
Here's mine!
[/img]
[/img]
bluesrxman
Your XTX looks great. Where did you get your seat post? Or did you make it?northernxtx said:Here's mine!
[/img]
northernxtx
Yes i made it myself. Bent the tubing at work and welded it up at home. The bracket is just rivited to the seat pan and it seems to be rigid and should hold up quite well.
BigAusti
- Dec 6, 2011
You should put those seat posts into production. Looks really clean.
