01blackspeeper
My buddy's nytro just started doing this. It will sit there and just free spin like there is nothing there and the clutch won't move. After a little revving it will finally take off but it always slips now. Is there bearings or something that need to be replaced or something like that.
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
I'd pull clutch cover.check cams for wear. Check rollers. See if they are loose. If they are they are worn bushings out. Also flip cover over and slip on to see how mush play in cover bushing there is. Just a few start points without seeing it eyes on.
x2 on the primary rebuild. just had to do this on brothers high milage/abused sled.
01blackspeeper
Will do thanks for a starting point. Never worked on a clutch before so might as well be a buddy's sled.
01blackspeeper
His sled only had 2500 miles on it.
might get away with a tear down and cleaning as it might just be full of belt dust or corrosion. had a few sleds i rescued that the primarys stuck until i took them apart and cleaned them.
Grimm
While you're cleaning up the primary, don't forget to service the secondary and change the drive belt. 10-1 says the belt is worn from all that spinning and no go. Service it all...they work together.
01blackspeeper
We put a new belt on it before we left a f have another new belt. The first belt is no good.
01blackspeeper
So I looked at it today and compared my clutch to his. I can move mine in and out when pushing on it and doesn't catch nice and smooth. His is a bitch to move and catches alot and won't return all the way and is slow to come back. What should I do guys never worked on a clutch before.
Grimm
Search this site. Topics to search:
- remove belt
- remove primary
- clean clutches
Plenty of info and pictures are found here
- remove belt
- remove primary
- clean clutches
