fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Race front end basics are 2" forward with a but more castor better a arm spacing for roll center and better shock angle. The subframe also being stronger.
Yes the original plastics are used just cut up to fit. I think you would have a home run with basic tubular arms and spindles for around 1000 like zbroz (for those needing replacement stuff and a price breakdown) and around 750 for subframe. You would get a lot of people that may have tweaked subframes jumping all over it.
bjowett
It has arrived, now the fun begins.
tyrion7s
Very excited to see how this project works out...
rrxx-1
Did you take it out for a ride? I was interested in that sled, but decided to make changes and spend cash on my sled instead. This will be a cool project.
bjowett
Nothing significant at this point. Low speed around the back yard showed no push, the sled just immediately turns.
I've got to put a reply in here to follow this thread. I know a front end is in my future at some point and this is very exciting. Please keep us posted.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
What are you going to do with the skid? Ohilins I'm guessing.....
bjowett
Ohlins for sure. Might also install a Mono shock skid with a new shock I'm developing for it.
yam177
MrSled said:bjowett said:Tom, thanks for chiming in... I'll be in touch about picking up vendor status again.
No problem. If it all works out well, I can work with you and we can put a test unit on my XTX . Be sure to make the kits useable for standard shocks too...that will help a ton for sales.
Only way that front end will work is with spehicle bushings in the shocks. Stock plastic will work just nees cutting. I cam provide Brain with nose pan templates if needed
yam177
bjowett
bjowett
Time to bring these exhaust flex couplers back into action. I built them back in 2005 for my Rage... along with a header, which met some studs a few too many times, so it won't be used here. These HD couplers have a slightly larger diameter and much smoother internal flow... plus they get rid of the exhaust donut (I do know about the copper donuts, I was one of the first to machine and sell them). These couplers also happen to be the same ID as the Phazer and 2011+ Apex couplers.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Are flex couplers better in principle than full one piece like Hindle design?
bjowett
Short answer, yes.
From what I can see, the Hindle is not a one piece... but rather uses several slip fits to absorb the rotation, vibration, and allow expansion and contraction. IME, using slip fits for these types of joints is an adequate and economical solution... that's not a dig, either, they can work very well. I think the flex couplings, when equipped with a proper flat spiral liner for extra strength and good flow, are higher quality and more appropriate solution.
bjowett
Scored a 128" Mono Shock II skid. Since the stock skid is already set back, I will eventually build this sled into a 136".
I'm also finally going to build an Ohlins Big 50mm Shock for the skid. Piston, shaft, and reservoir all grow in size on this damper. Here's one I mocked up a few years back.
