This sled is great... it works surprisingly well just cruising along, a bit stiff, but that is to be expected. However, when taken by the scruff, it simply rocks. Stable, no ski lift, turns when requested.
yam177
Stiff PSHHH go faster then it smooths out ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
edge_232
- Jan 15, 2014
- Madison WI
- 2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
Can't wait to hear about the fronted more. I'll be getting an A- Arm / spindle set up soon.
mattyg1405
Best advice everyam177 said:Stiff PSHHH go faster then it smooths out![]()
raginyamaha
x2!!yam177 said:Stiff PSHHH go faster then it smooths out![]()
![Sled1 :sled1: :sled1:](/styles/default/xenforo/smilies/sled1.gif)
No, even at full tilt, it does not smooth out that much.
Again, that was expected from this set-up. I can, and will, make it do everything well with a Mono skid equipped with an Ohlins PDS Shock.
![Tg :tg: :tg:](/styles/default/xenforo/smilies/tg.gif)
raginyamaha
so sad that Yamaha gave up on this setup. seemed to do better than the viper is doing this year....... late release a 2015 nytro or bring it back for 2016 with this front end Yamaha!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ![Die :die :die](/styles/default/xenforo/smilies/die.gif)
Superman
bjowett said:No, even at full tilt, it does not smooth out that much.Again, that was expected from this set-up. I can, and will, make it do everything well with a Mono skid equipped with an Ohlins PDS Shock.
I have Brian's Ohlins with PDS in the Mono shock in my Nytro. IMO the
Nytro really really likes the Mono shock rear suspension install.
![](/proxy.php?image=http%3A%2F%2Fi643.photobucket.com%2Falbums%2Fuu160%2Flakeffectsnow%2Fphoto-59.jpg&hash=ffc15d02337f8e19059ba54016d47561)
edge_232
- Jan 15, 2014
- Madison WI
front end set up
So are we able to get this front end anywhere? I'm looking to replace the stock front end on my 2011in the near future.
I thought someone on here bought a race sled and was going to try to fab the race front end for resale......... ![Jump :jump: :jump:](/styles/default/xenforo/smilies/jump.gif)
edge_232
- Jan 15, 2014
- Madison WI
I hope they do because it sounds like it's the best one out there that corrects the spindles, A-arms and shock angle.
Thanks, Chris. Looks awesome.
I'll be riding and testing this front end for the remainder of the season. When the snow is no longer rideable, I'll pull the front end and have a look at developing it into an actual product.
edge_232
- Jan 15, 2014
- Madison WI
Perfect! I'll hold off on getting a front end then because I really like the sounds of this one. Thanks for the response and best to you in reproducing the front end.
