bradfr
I just picked up a 2008 Nytro that is having issues with the starter. After searching around this forum it sounds as though I might have sheared bolts in the starter clutch. Right now the starter just spins freely and does not engage at all. We tapped on it with a hammer while turning over and also moved the primary around to make sure something wasn't locked in place. Does anyone know if its possible to pull the stator cover and flywheel with the motor in place for inspection? I read that people had to remove the subframe and tilt the motor to remove the starter itself. I own a 2008 Nytro as well and it looks like I might be able to remove the oil tank and there might be enough room to have a look from the side.
