apexltxgt11
I just bought a 2011 nytro with 219 miles on it. I've only put 4 miles on the thing, but when I brought it home last week and went to start it, it coughed and sputtered and stalled twice. Then when it start on the third attempt it backfired a couple times and I think only ran on two cylinders until it warmed up as right around when the red light went out it sounded much different (better). As it is still new I can take it back under warranty, but my dealer is 2 hours away....
Any suggestions?
Injector cleaner, spark plugs? I did put fresh fuel.
Any suggestions?
Fresh fuel and then let it warm up really good, and see if it run good before taking the next step.
apexltxgt11
It runs really good once warmed.
stook
mine did the same thing last year put fuel in it let warm up took it for a ride been good since
zeke66
Could it have too cold of plugs?
If previous owner started and didn't let it warm up, it can and will foul the plugs. May be able to just clean the plugs. Easiest way is take gas tank off but I have read you can in fact change them without if you have a 2 year old's hands.
- 7K
