jeremy377
Ive got an 08 40th mtx with a bent subframe since pretty much day one. My question is can i buy an aftermarket subframe (which im having trouble finding a website)or do i need to buy stock and beef it up. Any help or suggestions are greatly appreciated.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
http://www.diamond-smfg.com/Chassis.html only one i have seen... maybe there are others?
natedawgedog
diamond-s, i belive, is the only ones making an aftermarket cromoly or titanium subframe they are pretty spendy but they save a bunch of weight. you can buy an 09-present subframe also that are better than the 08 one you have and if you really want to beef that one up contact "grizztracks" here on ty he has a beefup kit that you can make the subframe very strong.
FloridaBoy22
Got the same problem. Just ordered the frame kit from Grizztracks, shoot him a pm for info. I did alot of searching and reading on here the past few weeks, depending on how bad the frame is bent, you can fix it.
I took the subframe off and disassembled it, did some tweeking and put it back on the machine. Put my a-arms and shocks on and finished tweeking and bending everthing back as straight as I can get it.
jeremy377
My right ski is back from the left at least four inches. Thanks for the reply I'll prolly buy a newer one from Yamaha and hope for the best. Might do skinz front end this year also.
FloridaBoy22
http://www.ty4stroke.com/viewtopic.php? ... s&start=15
Thats the link I was reading. Some good info and pics on page 2.
FloridaBoy22
Mine was almost 4 off too. Was alot of pulling to get it back. If you do get a new frame put Grizztracks kit in also.
BordnBill
I noticed something on mine that I never noticed. I was taking my Floats off and reinstalling my OEM coilovers and noticed the left coilover was almost rubbing on my top a-arm and the right side was about 1/2" from the top a-arm. Does this mean I may have a tweaked sub frame? I bought this 08 that already had a 09 sub frame installed. Never took a hard shot or anything off the front, so not sure if it was tweaked when I purchased it. Can I do the pry bar trick to maybe move it 1/4"?
sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
FloridaBoy22 said:Got the same problem. Just ordered the frame kit from Grizztracks, shoot him a pm for info. I did alot of searching and reading on here the past few weeks, depending on how bad the frame is bent, you can fix it.
One you bend the sf metal and try and move it back to position it will bend twice as easy on the next hit.
That is a temporary fix, you will need to replace the sf
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
Really is diamond s the only company out there that makes a light weight or new subframe for the nytro?... There most be some one else out there. But the diamond s ones look sick, but is the price worth the six pounds? Or do you think that they might save more
bholmlate
Diamond S is the only company that i have come across that actually sells either a Chromalloy one or titanium one. Its just too small of a market that people can't compete with OEM pricing after you factor in the fabrication time of a new one.
I have read on line that the sub frames are nice units but i think you are the only one who can answer the question if it is worth it for 6 lbs. i have read that roughly 6 pounds is what you save.
You do have to drill out all the body mounting holes yourself.
