Is whining normal upon initial startup? Seemed to improve after running a few minutes.
It has a sounds but not a whine.. maybe the belt is too tight upload a vid to youtube or face book and post link
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Tried but it says the file is too large. It only wines at idle. Once above 15-1600 rpm it goes away.
too big? For Facebook or YouTube?
I’m sure it’s fine.
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
I’m sure it’s fine.
my bad I tried to download it directly to here.
It’s all good. This site done allow VIDs
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Put on 85 miles, supercharger still whining at idle. Sent email to Rotrex to see what they say. Saw 5 psi boost at wide open, have not geared up yet. Runs dead even with my buddies 2018 Polaris 800 Pro-S and gradually pulls away on top end in soft wet snow. 10mpg for the day, but he lost a few mpg too over cold dryer snow. Was seeing 14mpg stock. Saw temps on the warm slushy wet packed snow up to 195 degrees with ski scratchers down, drops quickly to 170 in soft snow it was 40 degrees out. Do the rail scratchers cool better?
JayyDee92
- Dec 4, 2022
- Saskatchewan
- 2010 Yamaha Nytro MTX FX SE (SuperCharged)
What is the specs on belt or make of belt I need a replacement but can’t find anyMSN-0900 Nytro 180HP Supercharger Instructions (Update 8-8-11)
- Full Nytro 180 Supercharger installation instructions:
TSB-502B Supercharger Sprockets
- Proper pulley installation instruction bulletin:
I have finally started my Supercharger build on my 2009 Nytro XTX.
I opened the box for the low elevation kit and started tearing the sled down.
The kit comes with ice scratchers and an extra tunnel cooler.
Also in the kit comes gearing and clutching if you sled is not geared for the Supercharger.
I no longer have the sled. I know its a gates belt. Contact Ulmer Racing, He may have them. @SrxspecWhat is the specs on belt or make of belt I need a replacement but can’t find any
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
a quick search and someone on snowest posted this. Gates powergrip gt3, 720-8mgt-20. They said this was the one purchased from Ulmer Racing…What is the specs on belt or make of belt I need a replacement but can’t find any
Awesome!!a quick search and someone on snowest posted this. Gates powergrip gt3, 720-8mgt-20. They said this was the one purchased from Ulmer Racing…
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Looks like GT 3 series belts are now superceeded to GT 4 belts.
JayyDee92
- Dec 4, 2022
- Saskatchewan
Ya I ended up getting a gates GT4 threw gates them selfs. The 720- 8mgt -20 but it keeps slipping my off my tensioner can’t seem to get it right on it seem other listings for 600 - 8mgt - 20 don’t wanna keep buying bets that don’t work
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Please elaborate how it’s slipping off? Too loose? there should be about 1/4” belt deflection with 15 pounds of belt tension applied When the tensioner is tightened properly.Ya I ended up getting a gates GT4 threw gates them selfs. The 720- 8mgt -20 but it keeps slipping my off my tensioner can’t seem to get it right on it seem other listings for 600 - 8mgt - 20 don’t wanna keep buying bets that don’t work
JayyDee92
- Dec 4, 2022
- Saskatchewan
Ya I don’t know much about them I thought it was like installing a serpentine belt on a car but on the supercharger. But I left a 1/4 inch of slack the first time it made a few revaluations but soon as I went to put load on it it slipped to the out side of the tensioner causing it to jump off. Second time I went. A little tighter didn’t make 2 revaluations and it jumped it off again tried a few times and eventually got mad and left it alone but the sled won’t quite run rig he with out the belt either because it’s geared and clutched for it
