In my happy place
- Feb 7, 2015
- XTX Nytro
XTX Nytro
SRX 120
Have to replace left upper A arm and shock on a 13 XTX Nytro. Any information, tips / tricks appreciated.
I can't remember every step but it's really easy. You'll have to remove hood, then remove the three Philips head screws from the nose plastic . The bumper passes through the nose plastic, so you'll have to remove the top two bumper bolts and loosen the bottom two, which allows the bumper and the nose plastic to swing down out of the way, giving you access to the front of the upper a arm bolts. Remove the bolt and you can separate the upper a arm from the subframe. Remove the bolt going though the balljoint into the spindle and you are there.
Mountaintech
X2.
In my happy place
- Feb 7, 2015
- XTX Nytro
XTX Nytro
SRX 120
Awesome, thank you
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Make sure you use red loctite on the a-arm and spindle bolt when you install the new arm.
In my happy place
- Feb 7, 2015
- XTX Nytro
XTX Nytro
SRX 120
Replaced broken parts, was actually fast and easy job. Thanks for the help.
