pro116 said:With slydogs you have to change your toe.
What are the changes ??
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
sharky007 said:pro116 said:With slydogs you have to change your toe.
Brandon @ SlyDog told me 1/8 toe out total, I have 3/8 now and its horrible darting, I haven't adjusted since putting it back together this year but its way worse then last year, going to shim it and go back to 1/8 toe. Waiting for my BigDog skis to show up, if I cant get the darting better then I an going to try a Shaper Deuce.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
When I used Slydogs, I aligned the skis 1/4 inch toed in, at the recommendation of Ulmer Racing.
Unfortunately, it is normal for the bushings to wear out so quickly (on the Nytros), but definitely upgrade the bushings to oilite or nylatron to tighten the front suspension out.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
I wanted to powder coat my a arms and spindles think my bashings will get me by for 3000 miles?
- 6K
