WINDER1987
Put it in the trailer last season pulled it off today. And it wouldn't even try to. Turn over at first now it turns but won't fire it started once but quit. I always unhook the battery and store it in a good place on a trickle. And drain all the gas out. I put fresh gas in. It shows a solid orange light when trying to start and no Engine code
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Hook jumper cables up to a car battery and she if it runs
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
How many miles on those plugs?
WINDER1987
Ok I'm a dummy I didn't have my power commander wire hooked up. But I'm still getting a solid orange check engine light?
WINDER1987
Ok. Now that it's in the garage I shut it off and turned it back on and no light on now lol idk what's going on with it
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
ckeck fuel, air, compression, ignition. all you need ot make it run. maybe a mouse found its way into the engine compartment and chewed up some wires and when it started up it burnt through the last strand of wire left.....
larryh
- Dec 22, 2014
- 09 nytro/ 07 phazer/ 10 nytro mtx
I had a problem with my relays last winter and turned over and over, I call a dealer he told me to heat the relays and try that. It started but had a yellow light after running for awhile I shut it down then restarted it and code light was gone. I asked a dealer about it and he said it must have tripped a code when trying to start and when I started it the other time it did its system check and everything was good
