Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
- 2016 Polaris iqr 600
2013 nytro mtx 153 supercharged 180.
2012 yamaha nytro xtx (burned)
2009 polaris iqr 600(burned)
I would really like to do this mod . Hard to find someone selling one.
edge_232
- Jan 15, 2014
- Madison WI
- 2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
You need to contact some salvages yards & places that just part out sleds. Or worse case buy a new one $350 about. It is nice having one.
Justinthemnytro
- Dec 19, 2013
- Fort Kent maine
I found it online brand new but it was like 500 and some change.
edge_232
- Jan 15, 2014
- Madison WI
That seems high. Used the gauge will still cost you around $270 to $350. Keeping looking you'll find one.
th31nfamous
- Jun 16, 2015
- Quebec
- FX Nytro XTX
so an apex cluster wont work because it is a 4 cylinder engine right??
edge_232
- Jan 15, 2014
- Madison WI
You are correct.
You are correct.
X2 Correct!!
YamaHank
- Apr 1, 2013
- Boston, MA
- 2018 SR Viper RTX
Took everyone's advice in doing this upgrade. Thanks to these threads, this was a seamless process. One thing I did that I haven't seen anyone else post was purchase a new OEM wire lead, cut one end off of each, stole a pin from a cut-off for the clock lead and soldered/shrink-wrapped the long sides together. (This gave me the additional length to get the gauge placement higher + closer.) Had a machinist buddy CNC the two panels, powder-coated satin black and picked up some additional OEM rubber grommets to mount both plates...bit pricey & time consuming, but worth it.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
View attachment 115104 View attachment 115105
NOW THAT IS A SWEET INSTALL....
full tilt viper
- Dec 25, 2009
- Nytro MPI Stage 1
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
I did the same thing but didn't cover the loom with the nice grey plastic covering.
I bought the dual round end ram mount off ebay plus the big flat one and just reused one of the round ends as the backing plate for were it mounted to the hood cowling. Also reused the rubber grommets from the oem gauge. The ram mount make it so nice for adjusting it to just the right spot.
For anyone that needs an oem wire with pigtail for the clock PM me. I have a bunch!
Free?
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
I too got some CNC plates made up and mounted mine similar.
I love it. This gauge and the XTX suspension kit made my sled so comfy.
Now you just need to do my odometer trick to match up your miles!!
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
How does one do that? my sled had 9000ish when I took mine off but put on a gauge with ~11,000ish.I too got some CNC plates made up and mounted mine similar.
- 6K
