O2 Sensor aux. inputs WHERE TO TAP SLED WIRING???
LANEO
Guest
Chicagoland IL
Is anyone running a O2 sensor that has user aux inputs?
(The following manufactureres upgraded sensors have aux inputs, PLX, Zietronics, Innovative and even AEM I think.)
Are you monitoring any of the following with your multifunction O2 sensor. If so, can you tell me where to tap the sled wiring.
1. boost
2. knock
3. rpm
4. speed
5. intake air temp
6. coolant temp
I am installing a PLX R-500 which will monitor all of this and more but need to figure out the wiring of where to tap sleds harness.
I use one of the coil on plug wire coming from the ecm for RPM data
If you don't mind me asking what's that sensor worth I'm in the market for a sensor of some kind
Thx
I use a LM1 datalogger with the auxbox (rpm and 5 analog inputs) connected to a XD-1 gauge (afr display).
All this stuff if I remember cost me around 1000-1100$ CAN
Boost and intake temp needs to have the probe in the intake stream, somewhere from the outlet of the turbo to the back side of the carbs. The closer to the motor the more accurate. Knock and coolant temp will get its info from the coolant. Likely will to have drill/tap a hole somewhere coolant is. Rpm/speed not 100% sure on that, would need a wiring diagram. Hope this helps alittle bit.
