BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Is there any way to set up the PC3 with Hub to retard timing upon activation of nitrous only?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
p.m. allen he should know..
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
BADSLED said:Is there any way to set up the PC3 with Hub to retard timing upon activation of nitrous only?
Yes, I use the 'hub with toggle switch'. That way I have two maps ready to go at all times. The second map is for nitrous. It has less timing at peak, like -2 degrees.
87gtNOS
- Nov 30, 2005
- Toronto
Hey guys, I am selling this whole setup....3 full winters of 100% reliable FAST AS HELL fun!!!!
Selling:
-ZEX WOT switch
-TWO 2.5lbs bottles
-one 10lbs bottle for filling, with hose and filter
-Complete Holtzman kit, 90hp, dyno proven.
-all required wiring, toggle switch
-modded main fuel line
$600 firm + shipping!
check out 128mph any time!!
http://www.ty4stroke.com/viewtopic.php?t=55150&highlight=
Selling:
-ZEX WOT switch
-TWO 2.5lbs bottles
langow
87gtNOS said:Hey guys, I am selling this whole setup....3 full winters of 100% reliable FAST AS HELL fun!!!!
Selling:
-ZEX WOT switch
-TWO 2.5lbs bottles
You going boosted? Why are you selling?
87gtNOS
- Nov 30, 2005
- Toronto
langow said:You going boosted? Why are you selling?
I have bought a Yamacharger from CANADA'S BEST MOTORSPORTS AFTERMARKET PROVIDER!! Sled-werx!!!!!!!!!!
Once I get it, I'll do a complete write up!!!
langow
87gtNOS said:langow said:You going boosted? Why are you selling?
You think you'll be satisfied with only a 20HP boost after having so much more than that with the nitrous? Almost seems like a downgrade for you, no?
87gtNOS
- Nov 30, 2005
- Toronto
langow said:You think you'll be satisfied with only a 20HP boost after having so much more than that with the nitrous? Almost seems like a downgrade for you, no?
I think I'll be quite happy with the extra power I have all the time!!
ScottyD
- Mar 2, 2008
i thought last winter you were negative about the yamacharger, what changed your mind?
87gtNOS
- Nov 30, 2005
- Toronto
ScottyD said:i thought last winter you were negative about the yamacharger, what changed your mind?
You are correct ScottyD! Infact, I even raced one and beat it (on the motor) and radared 3 or 4 mph faster in 1300 feet.
Yamacharger 103mph
87gtNOS 107mph
87gtNOS with NOS 119mph in 1300 feet that day!!
I do now think it would be a great unit on my sled, giving me that extra few mph needed.
It SHOULD work!! It should.....
ScottyD
- Mar 2, 2008
so no more spray?, i see you have it for sale. i'm going to be ordering my yamacharger shortly also, for the money i think its a good " safe " bang for the buck
stephenpen
How easy would it be to put your kit on an 08 nytro.
87gtNOS
- Nov 30, 2005
- Toronto
This is still by far the best kit on the market.
I emptied another bottle yesterday on the lake, holding it for 2500 feet at least, just to prove to the local Z1T (all hopped up) that I can run with it!!
