rough rider
Has anyone played around with gearing on there 08 ltxs? Just wondering if this would be a good thing to do to gain more low end pull and quicker acceleration, I dont care about top speed as long as I still get around 85-90 out of it,
Has the vector gearing changed between 07 and 08?
My 08 seems to pull harder than our 05 rage.
radianguy
- Jan 1, 2007
08 LTX gearing is 22/39 according to the parts fiche I have seen, same as 05 rage.
The parts catalog is on the main page of the site
http://www.yamaha-motor.com/sport/myyam ... there.aspx
snoway said:Has the vector gearing changed between 07 and 08?
I thought the 08's pull alot harder too but there the same gearing.
Thanks 116, I was ready to open up the gear box to check.
I still might because mine is a demo sled.
deiinc
I got an 08 vector LTX GT. I was talking to my local dealer the other day about the grunt that my sled has
I have a friend that has an 06 Rage and the dealer said that he thinks that the 08' 120's flat out pull alot harder than any previous year 120's. I would have to agree as I have rode this Rage and my 08 Vector in the same day and same trails and I thought the same thing.
You can gear down, there are many options.
As for pulling harder... New part numbers on the 08 120 engine for cams, crank, cylinder head, cdi box... it's probably a 125+ or so these days.... just guessing.
radianguy
- Jan 1, 2007
Has anyone seen a dyno run for the 08 Vectors then?
Metallicat
No kidding? Hmmm...if there really are internal engine changes, it seems like Yamaha would be touting them in their literature. Did the clutching change at all?
bjowett said:You can gear down, there are many options.
The sheaves have new numbers, but all the weights. springs, and helix match.
Yamaha has underated the 130 in the FX, so it would make sense if the changes to the 120 are in fact performance enhancing that the number remains the same.
It would be interesting to see if the CDI would drop into the older machines and add a pony or two. Now that we are taking about it... does anyone have know the timing curve for the old CDI? Could be part of the top end limit... backing off the timing.
Until someone dyno's it this is all speculation.
I'm not shure you think yamaha would have said something.
The first time I rode an 08 vector.I thought I was on an apex at first.
There is something different there alot more powerful and I'm use to running well tuned in nytro's and vectors.
Metallicat
In one of the snomo rags, there was a blurb about the 2008 Vector and Olav Aaen said that it produced 122hp on his dyno (at least I think he was talking about his dyno). I don't recall which magazine Aaen contributes to, I'll try to see if I can find the article. But, if it is indeed making 122hp before break-in, then there may be some truth to the talk of increased hp on the 3 bangers.
Not to throw a wrench in the gearbox, but the manufacture date on my 08 vector GT demo is 06, probably late 06, but that would mean any engine changes that occurred were already in the works on the early demo sleds too, cause this sled rips!
I did put the ek plugs in it from day 1 so I guess i attributed any power gains to that over the 05 rage we have.
Anyone line up an 08 with an earlier model.
I might get a chance this weekend.
PAvector
- Feb 24, 2007
- Pennsylvania
- 2014 Yamaha SR Viper
Don't the 08's have 22-39 gearing and the 07's have 22-38 gearing. Could that be the feel of speed increase.
PAvector
PAvector
Vectors came with 22/38, the Rage came with 22/39.
- 6K
