hereismylife
OEM Yamaha or haulk hyfax saver wheel kit. Trying to decide on these set ups. Haulk is one piece and Yamaha are square. Anyone have any input on this?
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
I prefer the yamaha oem i like the way they mount better,i beleive as long as you loctite the mounting bolts & check the bearings every year they work great,Alot of people complain about them (coming loose or bearings)but it’s essentially the same small diameter wheels that were used on the upper rear suspension of the rx1& mine had about 6500 miles on them with the original bearings & never bothered before i lengthened & upgraded to a 2013 skid,granted they are mounted up higher but otherwise are still turning fast all the time.I like the way the mounting blocks of the oem mount to the rails it seems stronger & more precise just make sure you get the correct kit for the correct model& skid lengthOEM Yamaha or haulk hyfax saver wheel kit. Trying to decide on these set ups. Haulk is one piece and Yamaha are square. Anyone have any input on this?
hereismylife
Thank you for the input. I need to put them at the very front. I don't think the Yamaha blocks will go around the bends at the front.I prefer the yamaha oem i like the way they mount better,i beleive as long as you loctite the mounting bolts & check the bearings every year they work great,Alot of people complain about them (coming loose or bearings)but it’s essentially the same small diameter wheels that were used on the upper rear suspension of the rx1& mine had about 6500 miles on them with the original bearings & never bothered before i lengthened & upgraded to a 2013 skid,granted they are mounted up higher but otherwise are still turning fast all the time.I like the way the mounting blocks of the oem mount to the rails it seems stronger & more precise just make sure you get the correct kit for the correct model& skid length
Brotherdan
- Sep 8, 2017
- Belmont,maine
