Lgriinks
- Jan 22, 2015
- 2011 Nytro XTX
I recently put a OFT Relocater on my 2011 Nytro XTX. Love the handling, but every time I turn left the throttle cable is stretched and trips a error light. Do you have to put a MTX cable on or did something get put on wrong. I lengthened it as far as it could go but it still occasionally malfunctions.
shadow44
You have to make an adjustment to the cable, I take it the TORS is acting up. You do not need an MTX cable, the stock one works without issue, you just need to adjust it.
Did you reroute the throttle cable? It's in the instructions online. I only needed to go with the mountain cable once I added a riser to the relocator.
radianguy
- Jan 1, 2007
X2, need to re-route cable like instructions say.
Lgriinks
- Jan 22, 2015
- 2011 Nytro XTX
I will try rerouting it. I did adjust it as far as it goes. I think there may have been some ice build up that attributed to something being pinched.
mcamzr
I added the OFT relocate and a 5in LakeEffectSnow riser. All I did was reroute the cable a bit and put it behind the bars.I will try rerouting it. I did adjust it as far as it goes. I think there may have been some ice build up that attributed to something being pinched.
mcamzr
Here is a pic you can kinda see the cable behind the nav.
sprintcat
- Jan 13, 2009
- Rumford Rhode Island
- Nytro xtx
X3 no problems with mine ,just move the cable . You don't need to adjust it .
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
X4 no problems with mine in the last 3 years just reroute per OFT instructions.
Pete
Pete
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Says in instructions to relocate the throttle cable to the other side of bars
Alphadog
- Mar 6, 2015
- Appin Ontario
- 2018 Sidewinder
Where is a good place to buy the OFT Relocate ?
herndonp
- Nov 28, 2012
- Freedom,NH
Alphadog
- Mar 6, 2015
- Appin Ontario
- 2018 Sidewinder
Thanks Pete i have that i was just wondering if there was a supplier in Canada i could deal with, appreciate it though.
herndonp
- Nov 28, 2012
- Freedom,NH
No problem.
