On the Fence about a OFT Relocater.
I made my own oft kit and i love it, totally transformed the feel and the steering effort. With all the other mods we do to our nytro's this should be another to add to the list :Rockon:
It is one of the best upgrades I did. I can't think of any downsides to this mod. The parts are well built and it has held up perfect. All aftermarket products should be as nicely made and make as much of an improvement as this one.
I'm confused....
Revster, are you saying with the OFT relocator, you can install a 4" riser on an RTX without cable mods? I thought the limit was 2".
Just curious, if you used stock cables how did you do it?
OTM
I have a 6in on now with flat bars and could easily go 8. I had the 6 on with the stock bars that I think have a 2.25 in rise. All I had to do was move the throttle cable under the bars and I had full range of motion. That was to tall for me so I went with the flat bars so I am thinking if I go with the oft I will need a 4 or 5 instead of the 6. Am I right on that the oft also raises the bars as well as move them forward?
Off Trail Mike said:
I'm confused....
OTM
Yup. I just cut further up on the plastic rad shroud to give the brake cable more room, and ran the throttle in front instead of behind and she's GTG.
