RAMSOMAIR
The display in my gauge for the shock icon will not show up.
The plug to the shock got mangled and I replaced both ends with a trailer type connector.
I have power at the plug to the shock when tested with a test light. I plug in the shock and still have power but the icon will not show up in the gauge.
Is there something I am missing?
kidastra
Stupid question, but you are pressing the mode button right? Does the heated grip signal show up?
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
SO how DO we verify that the compression actually does adjust? Does it make a noise? Is there a small motor in there that turns a screw?
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
They are quiet, hard to troubleshoot?
RAMSOMAIR
shock
The grip icon shows. Cannot get it to show the shock icon while pressing the mode button, therefore no adjustability.kidastra said:Stupid question, but you are pressing the mode button right? Does the heated grip signal show up?
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
sounds like that is the place to start, if the icon is not coming up, it will not adjust. Another stupid question, have you checked all the fuses? Just a thought.
RAMSOMAIR
shock
Yes checked all fuses, hence having power on test light at shock.
DoktorC
Re: shock
What are you using to ground the test light?
RAMSOMAIR said:Yes checked all fuses, hence having power on test light at shock.
RAMSOMAIR
shock
I think I have it narrowed down to the solenoid.
Plugged my shock into a buddies sled that shows the icon with his shock. icon did not show when my shock was attached. Must be the wires in the solenoid or the solenoid itself.
If anyone has a new solenoid they want to part with shoot me a pm.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
You can buy the part from any yamaha dealer # 8GD-22961-09-00
