Daranello
Suspended
Will a rear Ohlins from a 2007 Apex 121" GT fit the new 2011 Apex 128" with the mono shock II??
I'm thinking of making the switch.
Thanks guys
Thanks guys
APEX 06 said:It should the 128" only has a little longer rail.
MrSled said:Dont bother with that Ohlins... the stock Valving in the new Apexes are way better...
Daranello said:MrSled said:Dont bother with that Ohlins... the stock Valving in the new Apexes are way better...
Even if your rebuilt the Ohlins? Im thinking at 6000miles the stock shock is due for a rebuild also
MrSled said:Daranello said:MrSled said:Dont bother with that Ohlins... the stock Valving in the new Apexes are way better...
Maybe ... you have only electronic compression, manual rebound... the stocker has a range of adjustment with the dial that adjusts both. The seal wont last as long... and they usually fail sooner ... Now you could have bjowett build you one and you may have better luck.
Daranello said:Cool, thanks guys can you send me This "bjowett" contact info? Thanks
