Daranello
Suspended
Will a rear Ohlins from a 2007 Apex 121" GT fit the new 2011 Apex 128" with the mono shock II??
I'm thinking of making the switch.
Thanks guys
Thanks guys
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
It should the 128" only has a little longer rail.
Daranello
Suspended
hmmm, http://www.ohlins.com has nothing listed. Don't wanna buy it if it doesn't fit
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
APEX 06 said:It should the 128" only has a little longer rail.
X2 this is my understanding as well
MT.man
The shock in all mono are the same basic lengh as they say the mega shock fits all mono rear susp. i can tell you that Yamaha has really done a good job on calibration with the new apex and you should ride it before you spend money to improve it. My 2011 (just like yours) is the first yamaha I have owned that I didn't spend money on to make it ride better. The only things that I have done are; dupont slides, exxcel wheels (before the sliders were available) and "Tuner skiis" highly recommened. Man its a long summer.
Daranello
Suspended
Don't you think the Ohlins would be better than the stock setup?
Dont bother with that Ohlins... the stock Valving in the new Apexes are way better...
Daranello
Suspended
MrSled said:Dont bother with that Ohlins... the stock Valving in the new Apexes are way better...
Even if your rebuilt the Ohlins? Im thinking at 6000miles the stock shock is due for a rebuild also
Daranello
Suspended
Daranello said:MrSled said:Dont bother with that Ohlins... the stock Valving in the new Apexes are way better...
Maybe ... you have only electronic compression, manual rebound... the stocker has a range of adjustment with the dial that adjusts both. The seal wont last as long... and they usually fail sooner ... Now you could have bjowett build you one and you may have better luck.
Super Sled
- Feb 25, 2009
- Summit X
MrSled said:Daranello said:MrSled said:Dont bother with that Ohlins... the stock Valving in the new Apexes are way better...
Daranello- An Ohlins Monoshock will fit in there -- same C to C distance.
Also, I agree for you to send it off to bjowett also. He can revalve the Ohlins to make it better. The quality of the Ohlins is great, but the stock valving is terrible on them -- to cushy and prone to bottoming. Bjowett can fix this. I have his contact number if you need it. I'd also have him make your compression a manual clicker just like the rebound is on the Ohlins, then you don't have to worry about broken EC wires.
Daranello
Suspended
Cool, thanks guys can you send me This "bjowett" contact info? Thanks
Daranello said:Cool, thanks guys can you send me This "bjowett" contact info? Thanks
bjowett is his username on this site. Contact him with PM.
- 6K
