SledHedz
Is is OK to run Mobile 1 Full Synthetic in my RX 1's? If so, what weight? 5w30?
What about a Fram PH9715 filter instead of the Yamaha filter?
All opinions and idea's will be welcome!
rxbrent
oil
I've ran mobil1 5w30 in mine since 900 miles no problems. not sure on the filter
SledHedz
Re: oil
Thanks Brent, I appreciate the reply!
rxbrent said:I've ran mobil1 5w30 in mine since 900 miles no problems. not sure on the filter
kinger
I run the napa 1358 filter and I think that is the same as the Fram. No issues either way.
Oil I was going to run 0w30 mobile 1 synthetic but not sure yet.
SledHedz
Thanks Kinger!
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Amsoil, Amsoil,......did I mention AMSOIL.
Both oil and filter. Been using this stuff along time now and love it.
-1CS
-1CS
sleddheadd
i run amsoil 0w-40 formula four-stroke it has a broader viscosity range than mobil! better cold weather flow and better warm temp. protection! it has an anti-rust agent for those off months when the sled is in storage, dispersent/detergent additives that will help neutralize high acid levels and combustion by products which are prone to smaller engines.also, has anti-foaming agents!
the 0W rating will guarentee a -60 degree pour point! which is going to mean easy cranking on those cold mornings!
of course i am kind of partial! lol.....any more questions feel free to ask!
www.ssoiltech.com
www.ssoiltech.com
sleddheadd
did i mention amsoils oil filters? lol.... 98.7%$ efficiency at 15 microns. thats the most efficient on the market today!
EAom103 for the rx-1
YAMAHAMMER101
I Have been running Mobil 1 0-40 and yamaha filter with good luck.
thinksnow
Somebody PM a price for the Amsoil filter and oil for a 2003 RX-1 Mtn. I might try if the price is reasonable.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
thinksnow said:Somebody PM a price for the Amsoil filter and oil for a 2003 RX-1 Mtn. I might try if the price is reasonable.
I think I payed something like 8 bucks, maybe 10 for my Amsoil filter for my Attak.
SledHedz
Here is some info I found on the Mobil 1 Website:
http://www.mobiloil.com/USA-English/Lub ... _5W-30.asp
Product Description
Mobil 1 5W-30 is a high performance fully synthetic engine oil designed to exceed the industry's toughest standards and outperform all conventional oils.. Mobil 1 5W-30 is engineered to help keep your engine running like new and extend engine life. Mobil 1 technology has been selected as original equipment by leading car builders such as, Chevrolet Corvette, Cadillac, Mercedes Benz AMG, Porsche, Dodge Viper, and Dodge Ram SRT 10.
Features and Benefits
Mobil 1 5W-30 is made with a proprietary blend of high performance synthetic basestocks fortified with an advanced additive system. Mobil 1 5W-30 is one of the most recommended viscosity grades for new cars. This oil is uniquely designed to provide unsurpassed levels of performance, cleaning power and engine protection, while meeting the demanding ILSAC GF4 performance standards.
Features
Advantages and Potential Benefits
Fully synthetic formula with SuperSyn Technology Helps prevent deposits and sludge build-up to enable long engine life
Excellent overall lubrication and wear protection performance for all driving styles
Outstanding thermal and oxidation stability Outstanding performance during the maximum oil change interval recommended in a vehicle’s owners manual
Enhanced frictional properties Aids fuel economy
Excellent low temperature capabilities Quick cold weather starting for ultra fast protection Helps to extend engine life
Applications
Mobil 1 5W-30 is recommended for all types of modern vehicles, including high-performance turbo-charged, supercharged gasoline and diesel multi-valve fuel injected engines found in passenger cars, SUVs, light vans and trucks.
Mobil 1 5W-30 is general purpose engine oil for all types of cars
Mobil 1 is not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Specifications and Approvals
Mobil 1 5W-30 meets or exceeds the following industry specifications:
ACEA A1,B1
API SM, SL,SJ,EC,CF,CD
ILSAC GF-4
Mobil 1 5W-30 has the following builder approvals:
General Motors Service Fill GM4718M
General Motors Factory Fill GM 6094M
Ford WSS- M2C929-A
Chrysler MS-6395
Typical Properties
Mobil 1 5W-30
SAE Grade 5W-30
Viscosity, ASTM D 445
cSt @ 40º C 64.8
cSt @ 100º C 11.3
Viscosity Index, ASTM D 2270 169
Sulfated Ash, wt%, ASTM D 874 1.0
HTHS Viscosity, mPa·s @ 150ºC ASTM D 4683 3.09
Pour Point, ºC, ASTM D 5949 -48
Flash Point, ºC, ASTM D 92 230
Density @15º C kg/l, ASTM D 4052 0.80
Product Description
Features
Applications
ACEA A1,B1
ILSAC GF-4
Ford WSS- M2C929-A
Chrysler MS-6395
Typical Properties
Mobil 1 5W-30
SAE Grade 5W-30
cSt @ 40º C 64.8
cSt @ 100º C 11.3
SledHedz
http://www.pureoil.com/smartlink/?partnum=L14612
http://www.wixfilters.com/filterlookup/ ... tNo=PH9715
Here are a couple of filter links that Cross References....
