Oil Change Question
Bodacious
Leelanau County, Mi.
I'm doing an oil change on an 06' 3cyl Rage. I have changed the filter, drained the sump, drained the crankcase, and cleaned the screen. How much oil in "Quarts" should I have to replenish the system with? I did a search but did not find a clear answer. Thanks in advance.
2.5 start then use the dipstick ,
do not screw it in to check.
