GPApex
My local dealership wants $250 to change my oil. So looks like im on my own...
It cant really be THAT hard is it?
WANN4STROKE
- Feb 26, 2007
- Anchorage, Ak.
- 2009 Viking
2006 ApxMtn-sold
2001 MtnMax-sold
1998 VMAX 500-totalled
Ulmer had some good instructions about getting to the filter when they sold the relocation filter package. There are other discussions about it here.
David
David
GPApex
I am serching. But with 12 707 results for oil change
Doing this in a few hours. Im sure ill find it, but pics would help.
Its my understanding that you need to pull the air box, battery box and skid off. Any special tools?
GPApex
Well thats it for me. got to as far as getting ready to pull the airbox out and im done. i dont even know where to drain the oil. my dealership stole my manual on me so that i have to go back to them for work. looks like it worked, however im going to use a different dealership. im gonna try redline in GP.
2XM3
down doad the apex manual from this website, it really is not that bad, oil drains from the tank and the bottom under the access panel.
Pull the lid off airbox, undo front rubber strap, loosen 4 small allen head clamps that hold it to the throttle bores. Unhook lines and remove airbox
Pull battery and battery tray.
you should see the filter now, and you can R&R it.
manual download,should still work
http://www.filesend.net/download.php?f= ... 03aa72011a
GPApex
So to pull out the airbox tray you just need to back off the 4 clamps? thats it? The manual doesnt help much...
Pull your headlight (10 mm bolt on each side) so you dont break the tabs on the top of the airbox. Tools needed for the oil change 5mm allen (body panel) 10mm, 12mm for the oil tank drain, 6mm for the oil pan drain, and a oil drain pan. I do not pull the battery or tray, instad, take out hte bolts that hold the tray in and stick my hand in from the clutch side to gain access to the filter. A filter wrench will help a lot especially on the 1st filter
