MikeAttakNYC
anybody do their own filter change on a nytro??? i did one on my apex, but my buddy wants to do his myrtos this weekend. any pointers or a step by step would be great
theCATman
Yep. Just jack up the front end, support it, crawl under & remove the plastic cover on the bellypan & there will be the filter. Just make sure the old gasket comes off the block. I guess the stock filters gasket is known for sticking on.
gormleyflyer2002
yes.......left and right lower cowls have to come of also before the belly pan plate comes of.
i would strongly suggest you buy a bunch of those little plastic push rivets.
search. i thnk someone did a play by play on the job. Its not so bad.
MikeAttakNYC
thanks ill give it a shot this weekend n see how it goes
unpride
Its simple. Just take your time and buy some extra darts. The filters on pretty tight so buy a wrench it makes it alot easier. When your at it take some time and check for loose bolts, you may find a few. Check the skid also theres one behind the front idler thats backing itself out(bottom bolt on front shock) If that one lets go it will cause some damage
arteeex
Check the the owner's manual for detailed instructions on the oil change.
MikeAttakNYC
thanks, but i know my manual for the attak says call the dealer. i hate that explanation!!!
Aaron P.
Definitely make sure you remove the gasket from the engine block, it will stick. The only engine failure my dealer has ever dealt with since yamaha started building only 4-stroke sleds, was due to double o-ringing the oil filter, and Yamaha still covered half of the repair costs. I don't think you will find that kind of help from any of the other big 4 with there 2-smokes.
Aaron P.
Aaron P.
MikeAttakNYC
ill have to remember to do that thanks
